Gronk
A little background.
I have the 9-speaker Shaker system. I started out replacing all the speakers with JBL GTO638's in rear deck, GTO628's in front doors, and GTO329's for the mids. I disconnected the A-pillar tweeters since the 329's are two-way, and wanted to avoid impedance mismatch by paralleling the two.
Next, I added a JL Audio XD600/6V2 amp. I ran the power lead through the passenger side grommet, and power ground to the rear seat bolt.
I'm using Molex connectors to grab the front/rear low level input signals at the factory amp connector (black) and running the signals with NVX 4-channel RCA
cables to the amp along driver side door sill trim. I ran two speed wire cables, one using 8-conductors for the front/rear speakers and the other using 5-conductors for the mids and turn on signal (NVX remote trigger relay) from the amp to the grey and brown Molex connectors.
I'm using two NVX RCA splitters to feed the two front signal to channels 1&2 for the 329's (set to HP at 300Hz) and channels 3&4 for the 628's (set to full range).
And the remaining two RCA's are connected to 5&6 for the rear deck speakers (set to full range). I set the gains with voltmeter at no load with Vol set to 24 using 0dB test tones of 50 Hz, 1khz and 2.5khz.
Everything sounds great and for improved bass will add a sub later.
When I start the car I get faint high freq tone that varies with RPM's coming from the 329/mids. These speakers come with capacitors which I installed in series with + connection per JBL instructions.
Also get some popping when doors open or pushing clutch pedal. I'm pretty sure my ground is good at the seat bolt.
I can eliminate the noise by disconnecting the brown Molex connector for the mids.
Thoughts?
Gronk
Thoughts?
Gronk
