Engine Code PO62B
JRuss
Cocoa,Florida
2015 Mustang GT
Anyone know exactly what the the NHTSA 10057810/TSB 44847 says about correcting the PO62B code?
I have the code but no check engine light or [FONT=&quot]any other problems. I read this is coming up on both the 2015 5.0 Mustang and the 2015 F150 truck.
[FONT=&quot]Don't care to take [FONT=&quot]it [FONT=&quot]back to the dealer to mess with until I know exactly what [FONT=&quot]the problem is.[/FONT][/FONT][/FONT][/FONT]
[/FONT]
JRuss
Cocoa,Florida
2015 Mustang GT
[/FONT]
Anyone have the TSB's available to them?
JRuss
Cocoa,Florida
2015 Mustang GT
I used a scanner. You are right the on board test is a cool thing to know.
I'm thinking this PO62B is a fluky think but would like top read the TSB myself. I did erase the code to seeif it comes back. I will probably have to join the ford servcie for 72 hours to find out. Sounds like it may be a common problem in some cars. Was hoping someone on here at access to the TSB's.
JRuss
Cocoa,Florida
2015 Mustang GT
I assume there is a TSB covering the code. At the top of the page it says 15 Mustang TSB's. If it were model year specific it would have a 15-44847.
JRuss
Cocoa,Florida
2015 Mustang GT
This website says: "Failing Component: Digital Instrument Panel".
Not sure what that really means, especially when they also say: "Internal control module fuel injector control performance". :shrug:
http://www.aboutautomobile.com/TSB/2015/Ford/Mustang/Digital+Instrument+Panel
[FONT=&quot]SSM 44847 - [/FONT][FONT=&quot]2015 - F-150 and Mustang - Diagnostic Trouble Code (DTC) P062B Stored in Powertrain Control Module (PCM) Memory[/FONT]
[FONT=&quot]Some 2015 F-150 and Mustang equipped with 3.5L PFI and 5.0L PFI Engines may exhibit Diagnostic Trouble Code P062B(Internal Control Module Fuel Injector Control Performance) stored in Powertrain Control Module(PCM) memory. DTC P062B is not a Malfunction Indicator Light (MIL) code and will not result in Drivability concerns. This DTC may have set during a quick key off/key on cycle event. If this DTC is present, clear the Diagnostic Trouble Code from the PCM. Do not replace the Powertrain Control Module. If DTC repeats, refer to Powertrain Control Emissions Diagnosis (PC/ED) manual Pin Point Test QE to diagnose the concern. Monitor OASIS for future updates.[/FONT][FONT=&quot]
[/FONT][FONT=&quot]APPLICABLE VEHICLES
2015 CAR: ZG MUSTANG (S550)
2015 TRUCK: FC P552 F150
2015 TRUCK: 00029 F-SERIES LD
2015 CAR: 00071 MUSTANG[/FONT]
