Eibach pro street coilover review
Niz55
Niz55
Us
17 GT350
had those plates before they are real good quality. so what is your caster spec after alignment?
tom_sprecher
Living Race Car Free
Marietta, GA
2016 GT Premium PP 6MT Race Red
3rd issue.
The tip of the front adjustment tool snapped on me while I was turning the adjustment rings. No problem you can always use a screwdriver or whatever you can stick in the hole. Maybe I gave it to much torque??
That tool looks like junk. You need something like this. They are sold by the pin size and adjusting collar diameter.
I've used coil overs that had collars and wrenches like this.
Niz55
Niz55
Us
17 GT350
Yes I know they are junk. The problem is the ring is a different design and unfortunately you can't use the wrenches. I really loves how kw put 1 set screw to lock everything down.
tom_sprecher
Marietta, GA
You could use the type wrench with the round pin and marked "Germany". BTW, all the coil overs I have used racing never had a setscrew. It would mess up the acme threads on the body. This is why they use a second "lock nut" beneath the adjuster instead. Unfortunately the adjuster and lock nut are two different diameters requiring two size different wrenches. :doh:
jon2002
MA
16 Mustang GT PP 401a TY
I do not know specifically.
I had my car realigned to GT performance package specifications for toe, camber, and caster. Do you have any caster issues after your coilover installation?
Niz55
Niz55
Us
17 GT350
no not at all. My caster is 7.6 on both sides. just wanted to know why you bought camber caster plates if you were not going to adjust your caster? The coilovers come with slotted holes to adjust camber.
Niz55
Niz55
Us
17 GT350
Well installed the 350LBS springs but the shocks up front are having little trouble keeping up on rebound. So going to return the 350LBS and try the 300LBS or maybe 275LB?
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
I'd give 300 a try. Similar to BMR handling spring rate. Sounds like these have similar or slightly less rebound damping than the FRPP track handling dampers, definitely less than Koni/Steeda. Ground control you can't come soon enough...
Niz55
Niz55
Us
17 GT350
I am heading down to eibach today to speak to Dave tech guy and if they have the 300lbs will buy it from them.
wildcatgoal
@sirboom_photography
TBD
I would get 275. That's about Swift Spec R range and those springs have hard-on-grade reviews by their owners.
Niz55
Niz55
Us
17 GT350
See that's the thing. Going from 250 to 275 might not make a difference. But 300 I am sure it will but I still have to worry about the rebound with the 300.
Niz55
Niz55
Us
17 GT350
So went to eibach and picked up set of 275lbs. They gave me really good price because I drove 30 miles. It came out to $83 for both springs. I haven't installed it yet but I will after my nap. But just pressing down the springs from a 250 and a 275 you can feel difference.
apex15stangPP
PHX, AZ
J
2015 Mustang GT PP
The spring game! I'm in that boat now. I'm currently at 425 front and 650 rear ( true coilover) best way to test is put a zip tie on the shock shaft (tight but not to tight) and go drive around slam on the brakes, take some corners, see what the zip tires tell you. You want atleast 1" left on the shock without bottoming out.
Niz55
Niz55
Us
17 GT350
275lbs ride just a bit stiffer. I would say it is a perfect match for these coilovers. I took it for a drive and I can strongly recommend these coilovers are excellent for a daily driver mustang and you can go really low without hitting the stops.
Niz55
Niz55
Us
17 GT350
BTW can't return the 350lbs springs because they are used.
