Eibach PRO-KIT Performance Springs
kapiteinlangzaam
Netherlands
5.0 GT Coupe 6MT PP1
Stiffer, obviously. And it likes to followcamber and imperfections in the road more.
Comfort thus far seems to be unchanged. Very happy with that.
Can't comment on hard driving handling, the weather is too grim to try at the moment
kapiteinlangzaam
Netherlands
Looks even better when it's clean :)
Kristian87
Super Moderator
Moderator
Newbury, UK
Mustang GT
Heartworm
Scotland
TVR Tuscan/ LR Defender/ Smart Roadster
Thanks to your pictures I ordered, should be fitted to the car when I collect it in April!
kapiteinlangzaam
Netherlands
You will love it I'm sure :)
Gibbo205
UK
UK 2015 Mustang & BMW E46 M3
Did they calm down the rear floatiness the stock PP springs give?
Reason I ask is because were all either calculating spring rate incorrectly or these springs are actually softer than PP springs, hence why your finding comfort is un-changed.
US PP Springs: Front 165lbs/inch & Rear 728lbs/inch
US Pro-Kit progressive springs: Front 200-314lbs/inch & Rear 800-914lbs/inch (30mm front / 25mm rear)
UK Pro-Kit linear springs: Front 150lbs/inch & Rear 650lbs/inch (25mm front / 20mm rear)
So if we are correctly working out the spring rate the UK Pro Kit is not only linear VS progressive but its also a lower rate spring compared to US GT PP springs.
Of course nobody knows the spring rate for the UK/EU GT PP springs.
Still these look to be a great option for those wanting the lower looks with absolute no change in ride quality, on the basis we have calculated spring rate correct, but two of us have done it now and both coming to same conclusion.
kapiteinlangzaam
Netherlands
I feel like the rear float is more contained, yes. It settles back to 'balance' much more quickly.
However, these things are always very subjective!
Gibbo205
UK
I am a little tempted to try them, just not sure how they would work with uprated dampers and uprated anti-roll bars, could be an in-balance and now I've switched tyres the cars compliance has improved a lot. :)
Toecutter
Scotland
Jeep
I have a set sitting here I plan to get into the sales thread this weekend along with a 2015-17 boot liner. No need for either now that I've moved over to the 2018 order
Manders Mustang
The Boss
Birmingham - United Kingdom
2016 Race Red Ecoboost
Boot liner will probably still fit, doubt the boots changed AT ALL for the MY18s. Structurally all looks the same, just some panel look alikes.
Toecutter
Scotland
Jeep
Your probably right Manders but it's just sitting here taking up space. May hold onto it until I'm able to see if it fits or not. No real hurry to shift it.
Manders Mustang
The Boss
May as well, no harm in it really ;)
kapiteinlangzaam
Netherlands
The continuing supply issues (in some parts) seem very strange.
A friend here in NL (not on the forums) just ordered a set from the local Ford Store.
Delivered in 4 days with zero issues.
Heartworm
Scotland
Got mine supplied and fitted from the dealer for collection of the car on the 21st, ÂŁ300 including the fitting from Ford, can't say better than that!
