E85
Gudz2015
omaha ne
2015 GTPP
What all is needed to go e85? it's pretty common in my area and cheap so I like to get some info on how to make a 15 run on it.
Jeepwx03
PA
68 Mustang, 15 Mustang GT PP, 13 F150 FX4
I would be concerned with Ford honoring your warranty if a conversation kit is installed.
Todd15Fastback
Atlanta, GA
Todd
2015 Mustang GT PP Fastback
JLT posted on Facebook their car on e85, tune and CAI...made 425Rwhp. Said no issues on e85 for a stock setup.
dwaleke
Jeep
My guess is larger injectors, perhaps a bigger pump/etc, and a tuner than can tune for the additional fuel.
Downside of E85 is we have a pretty small gas tank. You'll be at the pump more often if you regularly drive it.
beefcake
Bethel
2018 Ford Mustang
larger injectors are recommend for e85, you will push the edge of the stock fuel system with the oem's
we usually recommend 47's for n/a Id1000's for the guys planning on power adder down the road
FATHERFORD
Mustang
I know of two 15's with e85 with intake/tune/catback on the stock fuel system.
beefcake
Bethel
2018 Ford Mustang
That doesn't mean it's the proper way to do things.
you really should upgrade to 47's when n/a and e85
beefcake
Bethel
2018 Ford Mustang
the stock pump is fine, it's the injectors that are the main issue.
Typically n/a cars we recommend 47lb injectors for e85.
For power adder guys, our stage 1 fore systems will get you to about 800rwhp.
Then we have stage 2 to 4's available as well. The stage 1's are upgradeable to 2-4's later on if you get nuts with your build.
We also recommend the id1000 / 1300's for power adder e85 builds.
Gudz2015
Gudz2015
omaha ne
2015 GTPP
That's not bad if all you need is injectors and a tune. What kind of your mileage are people getting just day to day commute, 10c 16h? Or what %?
