Driveshaft 3.5 or 4 what's the difference
Racerx009
North Carolina
Anthony
2017 Ford mustang gt non pp
Hey guys I have a 2017 mustang gt N/A with 3.73, long tubes JLT CAI. I am thinking of doing the driveshaft 3.5 or 4 inches. Which would be better and why??? Or don't bother doing it at all. Thank you
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
All else equal, the 4" will be stronger, but will be heavier.
Racerx009
Racerx009
North Carolina
Anthony
Thanks for replying just trying figure out also if it's worth it for me since I am N/A but have all the mods done
whatsup62
Jupiter
It was the best mod I did when NA. Gives the car a much better response to pedal feel. You also shave off about 17lbs of rotating mass.
Racerx009
Racerx009
North Carolina
Anthony
Thank you for your input I will be buying one
69mach1-395
central nm, usa
2016 RR GT/CS
CF saved the weight, not the diameter. In general it has to do with shaft rpm...larger diameter will vibrate less at higher rpm IIRC.
whatsup62
Jupiter
  1. CF saved the weight, not the diameter. In general it has to do with shaft rpm...larger diameter will vibrate less at higher rpm IIRC.
    Are you referring to my statement? I did not run a CF shaft when NA. I ran a Aluminum Dynotech shaft (which I would highly recommend over the others out there). Believe the stock shaft and center support was like 34lbs and the new Dynotech was like 17lbs.
69mach1-395
central nm, usa
2016 RR GT/CS
Well I wasn't sure if the OP was thinking of CF but you provide good info for sure.
Racerx009
Racerx009
North Carolina
Anthony
Thanks for the info I will be going with the 4in aluminum.
