TicTocTach
Finally clean, and decent light to see the splitter installed...
I have 20mm spacers and long studs as well as -2.0* of camber. No rubbing at all - but I am not lowered at all. I think the Magneride cars came slightly lower from the factory. Lots of folks use a 25mm spacer, too, so check what works for your setup.Any rubbing with the 11" ET50s up front?
super clean car i like it! what part of dfw are you in, im over in saginaw right nowFinally clean, and decent light to see the splitter installed...
Thanks! Just east of you in NRH...super clean car i like it! what part of dfw are you in, im over in saginaw right now
+50 won’t clear the strut with much less than a 20mm spacer. That’s where the long studs come in - you can use a hub-centric spacer that only relies on one set of lugs to stay tight. I’m using GT350R hubs and billet spacers from Optimum Performance. I have about 1/4” clearance between the wheel and the strut.I have the SVE X500 wheels in 19X10 ET35 and 19X11 ET50. Think of going with a square setup of 19X11 all around. I would only do a 5mm spacer up front. The magnaride cars are the same ride height as the non magnaride. A 20mm spacer is huge, more than I would ever want to use.
25-30 seems to be the range for front wheels if you don’t want to run a spacer or don’t care about rotating tires. There are wheel sets like that out there, and I think the GT350’s do something similar.Thanks for the info...basically you need an ET30 wheel for the 19X11.
not sure if you're on face book at all but theres a group call "the stable" we usually hang out and do meets lotsa good people and carsThanks! Just east of you in NRH...
Thanks, I'll take a look - DFWS550's is the only local-Mustang-focused FB group I'm on.not sure if you're on face book at all but theres a group call "the stable" we usually hang out and do meets lotsa good people and cars
they are good guys too we go to their meets at flipsThanks, I'll take a look - DFWS550's is the only local-Mustang-focused FB group I'm on.
what a shine!i thought i'd stay with matte black wheels; however, the color just wasn't growing on me. so, I had them powder coated tuxedo-black, which is really a darker grey (hex color 313131) with metallic flakes. close up, the wheel looks more grey than black. lowering springs are next; hope to have them installed in a month or so.
