Elp_jc
Okay guys, finally got home, and the first project of the day was to deal with the stupid ball. Ha ha. Removed it, and it only had 6 turns. Plenty of unused threads inside the ball, so put it back again, and I was only able to give it about 1/4 turn more, which required quite a bit of force, so no freaking way an additional 3/4s was in the cards. Removed it again, and tapped it as deep as I could, which was about a turn more, before the tap bottomed out at the end of the cavity. Could only give the knob 7 turns, so only an additional one. There's still a visible gap. Since threads are not the problem, that means either the ball or the shift shaft have tapered threads. Which ones do you guys think it is??? If it's the knob, I could sand down the top threads on the shaft, so the ball can screw in deeper. Let me know what you guys think. By the way, I need 2 full turns more, to be more or less flush with the reverse lockout.
As a final thought, maybe the differences are with the lockouts, no? Mine might be seating lower than others, thus opening a gap below the ball. But rather not mess with that
