DO NOT FIT: MMD No Drill Hood Struts
klumpikat
Chick driver
La Jolla, CA
Liz
2015 GT Premium, 2023 Mach 1 Premium
It's the pedestrian impact pop up hoods mandated in Europe that require the special hinges.
Started to realize there may be some law behind it. :p
Gibbo205
UK
UK 2015 Mustang & BMW E46 M3
After spending over an hour trying to get these to fit and allow the bonnet to shut without catching or rubbing,even modifying the brackets to get them to align better did not work.
I went on youtube an watched the installation video and on closer inspection the EU bonnet has completely different hinges which reduce the gap that the strut is supposed to slot into, and have a tab that impacts the strut no matter which way it is set up.
so just in case anyone is thinking of buying these, DON'T as they DO NOT fit.
Damn I've got MMD as well. :(
So is it stock o.e. part of the hood hitting against the gas strut? Or is it part of the metal in the MMD kit not fitting right or hitting something as I suppose that could cut and modified.
SamH_
SamH_
Essex, UK
Sam
Mustang GT V8 5.0L | Fastback | Customisation Pack
the part of the hinge i circled in the pictures that posted earlier, impact onto the body of the gas strut itself, we tried minor modifications to the brackets, and swapping the sides and gas struts around but there was no way we could get them to align perfectly.
its such a tight gap that the strut has to squeeze through, and the chassis is in the way of where you would need to put the strut-end to get a perfect line.
id suggest trying to to return them, and getting the Redline or steeda ones instead.
Sent from my SM-G925F using Tapatalk
Gibbo205
UK
Did you trying flipping the struts around so they are effectively upside down.
If its the actual strut catching I'd though the redline would as well unless the MMD strut body has more girth.
SamH_
SamH_
Essex, UK
Sam
when the strut is compressed the body is in the same spot still impacting whichever way up it is, the redline/steeda ones fit at a completly different angle, thats why they fit but the MMD ones wont
MMD
Redline
AMAlexLazarus
Malvern, PA
www.americanmuscle.com
Alex
'14 F150 EcoBoost/'08 Bullitt
Hey Sam - I'm sorry about the delay on my end and to hear about this. Gibbo just shot me a PM and lead me to this.
This isn't any good at all and I'm going to work to have the listing updated on our end to ensure that no-one in the UK is going to run into this issue moving forward.
In the meantime or whenever you're able to do so can you please PM me your order information so I can look into this further?
Thanks in advance and I'm sorry about the trouble but I'll make sure that MMD is aware of this.
Alex
POJ 1
Auckland New Zealand
Phil
2019 Bullitt build no.301
Alex
the Mustangs for New Zealand and Australia have the same hinge so you better expand your warning list
Best wishes for 2016
AMAlexLazarus
Malvern, PA
Alex
Alex
Thanks Phil! And same to you guys down under. I'll make sure that you're included.
Alex
AMAlexLazarus
Malvern, PA
Alex
Hey Guys - Can you let me know what the numbers/characters are on here so we can look into it further.
SamH_
SamH_
Essex, UK
Sam
007 GR5B 16800 AC R
is the right hand hinge
SamH_
SamH_
Essex, UK
Sam
guys redline struts definitely worked, the holes on the hood side needed elongating by a 2 mm at a 45 degree angle to allow the to rotate in the place correctly but once that was done they fit perfectly
AMAlexLazarus
Malvern, PA
Alex
007 GR5B 16800 AC R
Thanks Sam - I don't want to assume but something's telling me it might be identical for the L side too.
I'm working through PM's right now.
Alex
Gibbo205
UK
Alex
I think this might effect not just RHD but also LHD euro cars as well, the hinges are different on EU Mustangs due to pedestrian safety bonnet explosive devices built in. :D
SamH_
SamH_
Essex, UK
Sam
Alex
left side is different, incase you cant read the image i have, GR3B 167801 AD L
AMAlexLazarus
Malvern, PA
Alex
Alright both of you guys are going to have to elaborate on that one.
Did I mention that I was just over there a few weeks back? I'll pay handsomely for Walkers or a pre-maid sammich from sainburys. :headbonk:
Edit - Sam - Thanks for letting me take a look, Losing my vision here! I'll make sure all of this makes its way over to MMD
