decklid emblem change
svtfever
ALEX
TX
William
2019 GTPP1
how do I remove the rear emblem? is it major surgery ?
Infamous
President of Honda
2015 Mustang GT w/ PP
You'll need to purchase a new decklid. If you remove the GT badge off of the stock decklid it will leave holes. I recommend purchasing the Ford racing decklid. Good luck. :cheers:
svtfever
svtfever
ALEX
TX
William
2019 GTPP1
I'm changing it to a matte black
svtfever
svtfever
ALEX
TX
William
2019 GTPP1
do I just rip the old one off and stick the new one on? do I need to take apart the trunk?
Infamous
President of Honda
I suggest looking up the CJPP video. Straightforward and simple replacement.
svtfever
svtfever
ALEX
TX
William
2019 GTPP1
I could not find his video of the rear decklid emblem replacement
Bobsp12
Super Moderator
Moderator
Adelaide, South Australia
lots of Fords
You need to remove the rear decklid panel first. The factory badge has four plastic pins that protrude through the panel that are heat flattened on the back to retain them. You just need to cut off the flattened platic on the back of the panel with a sharp knife. I used a drill with a largish bit to just cut into the plastic pins from the back a little bit and then flicked the plastic off with a knife. The stock badge then just lifts off, it has no tape on it. The replacement badges usually have the locating pins and double sided tape. Just push it on and it's done. Refit the panel.
Panel on and off is about ten minutes, badge change is about the same.
svtfever
svtfever
ALEX
TX
William
2019 GTPP1
You need to remove the rear decklid panel first. The factory badge has four plastic pins that protrude through the panel that are heat flattened on the back to retain them. You just need to cut off the flattened platic on the back of the panel with a sharp knife. I used a drill with a largish bit to just cut into the plastic pins from the back a little bit and the flicked the plastic off with a knife. The stock badge then just lifts off, it has no tape on it. The replacement badges usually have the locating pins and double sided tape. Just push it on and it's done. Refit the panel.
awesome thanks
