D5 Beadlock Wheel
JGARCIA69
J
2015 Mustang GT
Hello,
I recently purchased two rear 17x10 wheels Forgestar D5 Beadlock. Also finally received two new tires M/T 305/45/17 from JEGS.
I’m having trouble putting this tire on my wheels. It seems the tire is a bit small, it won’t to over the ridge of the bead wheel. From what I’ve seen on YouTube it’s fairly easy.
Any advise would help.
Thank you
CORNYOTE
Oklahoma
Alex
2019 GT
did you completely remove the outer beadlock ring?
JGARCIA69
JGARCIA69
J
2015 Mustang GT
Yes the ring and bolts are off.
Stephen@lethal
2020 Mustang Gt500
They should go on pretty easy, I have the same size and mine went on with no issue, I had to use a little lube to get them to slide over them however.
JGARCIA69
JGARCIA69
J
2015 Mustang GT
I finally located a high performance shop that have done this of type of installations..
Thank you for help.
Tonymustang302
Chicagoland burbs, IL
Tony
2017 Turbo GT, 2019 GT350 racecar, 2021 GT500
What size tire did you go with and is your car lowered?
