WorldwideStangs
So I just got my Corsa Active exhaust system installed on my 2020 Mustang GT and for some reason when going to Quiet or track mode, the valves open and close then go back to normal mode. Checked to make sure the motors and spring were installed correctly, and they are. Disconnected the battery, checked wiring and the issue still persists.
Corsa says they’re sending replacements tips and valves, but I don’t think that’s the problem. The factory active system worked perfect.
I’ve read that swapping the motors to opposing sides has fixed it before and replacing the motors have fixed it for others.
Has anyone else had this issue and have a fix? Debating about taking it to Ford and seeing if they can fix the issue if the replacement stuff doesn’t work, but hopeful it does.
