Cold Start Motor Shaking
cpelaez1
Silver Spring, MD
Cristian
2016 Shadow Black 5.0 Vert
Hey everyone. I got a 2015 V6 about a week and a half ago, and I notice that on cold starts the motor shakes almost as if the idle is too low. Once the engine is hot, the shaking ceases. Any ideas to what this could be? I have seen a lot of threads of high RPM at cold start but nothing like mine.
Thanks.
SpeedLu
some swamp
2020 Premium PP1 Mustang GT, 2017 F-150 Platinum FX4
Your Cyclone is just so damn happy to be on that it can't contain itself.
six_shooter
Joe
2015 Mustang V6 DIB, 2018 HD Iron 1200
What is your RPM at cold start? A little shake is normal.
jasonstang
Denver, CO
2017 GB GT/CS 6MT
My GT does it a little bit when warming up. Just some slight dance for maybe 5-10 seconds.
Happened to my E46 BMW too.
Tems
Pharr,TX
2015 DIB Mustang
I think mine was doing the same thing when I first got it. Was the RPM stick jumping up and down? between 1-1.5?
dh3605
Nashville Tn
2019 GT, 301a, Auto, Black, Black accent package
Thanks.
had same issue on gm product and it wzs the sensor telling the fuel system if it was getting E85 or not. I let it go as once it ran a bit, all was good. Turned out it was pumping fuel as if it wzs E85 when it was not and washed ot the cylinder walls. Luckily Gm replaced the long block under warranty.
cpelaez1
cpelaez1
Silver Spring, MD
Cristian
The RPM stick was jumping up and down slightly yes.
DANA44
Central Connecticut
2016 v6 convertible
I've noticed too. Isn't there when extremely cold but when in the 40-60 degrees seems to hunt for a minute.
yamilselman
Miami
2016 Mustang V6
I have a 2016 Mustang v6 and has the same issue a random kick when the car is idle or standing at an stoplight. I was curious about this and I plugged a code-scanner to the car and what I found out was a "dtc freeze frame code p0306", that means a misfire on cylinder 6. I have not had any check engine light since I bought the car 6 months ago, so I asume that this is happening not too often enough to trigger a check engine light.
My question is Any of you have connected a scanner to see if you have had a misfire on any cylinder even if you never had a check engine light? maybe indeed there is an issue with all the 3.7 engines.
