HBTD
- Jun 22, 2015
- Huntsville, AL
- 2015 GT Convertible
The battery is a duralast from autozone.Sounds like the battery storage (AMP) cold-cranking power. Could be failing to store the energy it takes to turn the motor over.
The voltage reading seen may very well be what is known as a surface charge.
The only real way to diag is with a load test of the battery.
What is the battery brand & model type in the car now?
One more question, when starting the car. Do you allow a moment for the electronics to boot (stabilize)?
Or press a button going for the start with one quick jab. Not a great way to start the car.
The start button is not a light switch and does not operate the same The computer in the car and everything that has a computer.
Runs a post @ power on, checking the hardware and system parameters. That being things like sensors or battery voltage.
When they pass the post, the computer is ready processes proceed...... in this case motor turns over.
This is quick but jabbing the start button quickly can ask the computer to turn over the motor before it's done posting. The result the user finds a slight delay
"taking longer to start" is the delay occurring from the time you push the start button to the time the motor turns over.
OR the motor is turning over slower?
When I get in the car, I depress the brake, then push the starter button. I don't wait a specific time, but I haven't changed my routine. The delay is in the motor catching and starting, not the time before it starts cranking. It is not long but noticeably different than before, almost like when I used to have cars with a carburetor, sometimes you have to crank it a while before it catches and starts. I'll try to check with the voltmeter when the artic blast is over (car is garaged but it will still be abnormally cold tomorrow AM).
