Codes
christian
Happy Member
Bellefonte, PA
2015 Guard GT
P0019
P0300
P0307
P0308
Timing? Any other ideas? Just started it up after OPG install and this...
If timing is off, wouldn't all the cylinders be throwing?
Thanks guys
Jeff_oddo
Colorado Springs, CO
Jeff
Mustang GT Premium
christian
Happy Member
Bellefonte, PA
2015 Guard GT
I know what the codes are
P0019 crankshaft position sensor
P0300 multiple cylinder misfires
P0307 number 7 misfire
P0308 number 8 misfire
Jeff_oddo
Jeff
Mustang GT Premium
Did you follow the timing procedure correctly? There is one in the DIY section
christian
Happy Member
Bellefonte, PA
2015 Guard GT
I'm really bummed. Had a very mechanically inclined friend do it...he said he set the cg 12 and pulled both chains off together at that point. Then set it to 12 when reinstalling and put them back on just like he took them off
jabrax
Montgomery County PA
Jeff
2015 ruby red PP GT
im no mechanic but I have read threads here with this issue and recall it having to do with not rotating 1 full turn before setting position. Just throwing stuff out there
RockStang
AA county MD
Joe
2016 GT Whippled
Sorry man but your timing will have to be redone. It's very easy to slip a tooth when putting the chains back on. It happens when you turn the crank to put slack in the chain to get the chain guides back on. Happened to me twice when doing my OPG but I caught it before putting it back together.
christian
Happy Member
Bellefonte, PA
2015 Guard GT
Thanks everybody for the reply. Left hand side was off 2 links.
christian
Happy Member
Bellefonte, PA
2015 Guard GT
How do you know it's exactly 5 o'clock? Any tips on that?
