Code p00c6
Alanggg
San Antonio tx
Alan Gutierrez
2019 mustang gt
Hey guys so today I was driving home and I only had 4 miles to empty took an exit to go pump gas but all of the sudden car cut power and died . I thought I ran out of gas and got a jugg and pumped 93 on it but now car won’t start and got the code p00c6 . Car is Lund tuned only mods it has is headers , has anyone ever had this problem?
RichGT350R
PA
Rich
2020 Shelby GT350R HEP
P00C6 is rail fuel pressure fault. Sounds to me like your miles till empty are off by (4)
Try cycling the car on and off without cranking to get the fuel back through the system. Or you may need to bleed out the air at the rails.
If you did get it running, the code should clear after a few miles.
Alanggg
San Antonio tx
Alan Gutierrez
2019 mustang gt
Thanks you
Most likely if the OP's fuel gauge is off by 4gal +/-, then OP might need to adjust the AFE Bias calibration of the cluster. It's been discussed on here elsewhere as others have found that the S550 MPG readings are not accurate or in some instances not being calculated correctly in both the Analog and Digital clusters. One can confirm this if they did the old fashioned MPG pencil to paper (or Excel sheet) math.
To adjust the AFE Bias, you first need to access Engineering Mode; the below links demo how to access EM.
If you have a 2015-2020 with the ANALOG gauge cluster, you should be able to enter the “Engineer Test Mode”.
Follow this link:
https://www.mustang6g.com/forums/threads/engineering-test-mode.27581/
If you you have a 2018-2020 with the DIGITAL cluster, you should be able to access the same test mode found here:
https://www.mustang6g.com/forums/th...n-18-digital-dash-old-way-doesnt-work.115231/
To understand how to adjust the AFE Bias once in Engineering mode, go to this informational thread (starts off with Analog cluster):
https://www.mustang6g.com/forums/threads/how-to-adjust-your-indicated-average-fuel-economy.48903/
To do the same AFE Bias adj. in the Digital Cluster, hit this portion of the thread:
https://www.mustang6g.com/forums/th...dash-old-way-doesnt-work.115231/#post-2425775
Additional thread regarding the AFE Bias:
https://www.mustang6g.com/forums/threads/mpg-display-correction-adjustment-afe-bias.99044/
