v8hgt
- Mar 31, 2016
- Cheshire, UK
- Nick
- Race Red GT PP Coupe
- Vehicle Showcase
- 1
Has anyone else seen this DTC "Code: B2486 - Left Side Repeater Lamp Output Circuit Failure"
The symptoms are the triple blink doesn't work when pressing for left. And.. If you indicate left by pressing the stalk all the way down, then leave it indicating left for 30 seconds+, then cancel by moving the stalk to the centre position, the car continues to flash the left turn signal until you turn the ignition off.
Note all turn signals are flashing just fine, its not like there's a bulb out etc. Also the problem first occurred during very heavy rain which may be a factor.
The car is EU export spec with the repeater in the wing mirrors. The code suggests to me that the repeater in the wing mirror is at fault, even though its clearly flashing fine.
any help or advice much appreciated.
