Bridgie
- May 25, 2015
- Raleigh, North Carolina
- Dave
- 2015 GT fastback. PP, 50th trim, Black
So after spending quite a time using the new search function to little effect.. I had to make a new post.
First noticed that the pedal has dropped about 1-1 1/2 inches from fully up when I got in the car yesterday morning. 10 minutes of pumping lifted the pedal and all was OK.
Following a total clutch failure in March, I have replaced the complete clutch & flywheel (Exedy Mach 300), new slave, added Steeda braided line, fixed the reservoir hose fitting issue...
Vacuum bled the complete system Brakes and Clutch last night, as I am off to the track in 2 weeks. Vacuum was good, holding for 10 minutes using a Mityvac direct to the Fill cap.
Came out to the car again this morning.. Same thing, clutch pedal down. returned after pumping.
We will get under the car tonight for much closer inspection of all the fittings.
Any ideas..?
Master Cylinder - Slave (Again) - Leaks (obviously, but will check again) - Air in system
Anyone seen issues of Slaves failing prematurely.?
I don't really want to have the complete tranny out again, but if its a must, then I guess it will be.
Thanks in advance.
Bridgie
Any ideas..?
Thanks in advance.
Bridgie
