Clutch stop. Had one on my BMW, worked great. Thought about it for the mustang but haven't done it for a couple reasons....1 Switch to start car has to be made for car to start, clutch has to pretty much go to the floor to make this switch. 2 Clutch stop is only gonna limit a bit of travel a the bottom of the pedal... does nothing to fix high engagement point. 3 concerns about clutch not fully engaging if not fully depressed.would it be easy enough to put a blocker or something on the floor that just stopped the clutch from going all the way to the floor?
Yeah I had plans to do the same but ran into the issue of having to push all the way down for the fuel pump to kick on. :frusty:Clutch stop. Had one on my BMW, worked great. Thought about it for the mustang but haven't done it for a couple reasons....1 Switch to start car has to be made for car to start, clutch has to pretty much go to the floor to make this switch. 2 Clutch stop is only gonna limit a bit of travel a the bottom of the pedal... does nothing to fix high engagement point. 3 concerns about clutch not fully engaging if not fully depressed.
