Center Bore?
xjester
Chicago, IL
2016 Mustang GT Prem w/PP
Ordered some spacers from Motorsport Tech a few days ago. When the invoice arrived, I noticed that there were two center bores listed - 70.3 and 70.5. When ordering, I filled in the center bore based on a quick search of what the center bore should be for a 2016 GT w/PP. The sources I've discovered all say 70.3:
https://www.americanmuscle.com/wheel-tech-guide.html
https://lmr.com/products/mustang-wheel-offset-guide
However, Motorsport Techs website has a 70.5 center bore set as the default when you select the vehicle. I didn't realize this until after making the order. Yep, I suck.
So which one is right?
I seem to be screwed about this - Motorsport Tech is closed until April 9th but the machine shop is making order right now. Called, and just get a message. Emailed them with no luck so far. No clue if I can catch this before they are made. :frusty:
