Shdwrlmstang
Yo thanks so much understood I will definitely change themCheck this thread which is similar:
https://www.mustang6g.com/forums/threads/car-swaying-side-to-side-at-high-speeds.115937/
It may have some info for your swaying issues.
Also, you should always be running equal tire pressure all around on a street car. Tire pressure should always be taken when the tires are stone cold. Door VCL, IIRC is 32 or 33 psi at all 4 corners when cold. When the tires heat up from driving that cold psi will also rise, slightly. You may see 35-36psi when warm (even on cold days).
I’m right next to you in NJ, same exterior temps, running equal tire psi at all four corners. If you’re running unequal psi, it’s going to cause performance issues at higher speeds, especially maneuvering from lane changes, curves on/off ramps as the body of the car rolls/leans left or right from weight transitioning.
