Can I add a B&O sub to basic speaker setup 2018 GT Premium? (car came without a sub)
Rooz
Canada
2018 GT Convertible
I have the blue socket in the passenger side trunk area, so I believe I can add the original Shaker sub if I change the DSP. My question is can I add the B&O sub to the car? Do I need to get the same DSP as I would with Shaker sub?
Bassackwards
Nashville
2022 GT/CS convertible
I added a 12" sub in a custom enclosure and it blows the b&o away!
I don't think you have the correct amp either so it is not as simple as just plugging it in.
Rooz
Canada
2018 GT Convertible
I have the blue socket needed for Shaker pro. Just want to know the same wiring and harness work with B&O
Rooz
Canada
2018 GT Convertible
I can get an O&B sub for free. Hence I’m aksin
Rooz
Canada
2018 GT Convertible
No it is behind the kick panel by your foot. You should have an amp but not the right one
Is that not the DSP?
If so, will the DSP that works with shaker pro also work with the B&O Amp?
I'm looking to get this DSP: FR3T-18T806-CP. If this works with both the Shaker amp and the B&O, then I might as well take the B&O.
Bassackwards
Nashville
I don’t know whether or not that amp will work. Says 15-17 which is pre b&o.
I abandoned mine and installed a new amp in the wheel well. It was easy and sounds much better.
Bassackwards
Nashville
That still doesn’t address the issue that basically no one here is satisfied with the b&o sub and works to replace it asap.
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
There’s the Shaker system which was pre B&O. The amps are not the same. The B&O uses a canbus system in the DSP amp to communicate with the APIM. Simply throwing in a B&O amp in a 2015-2017 or a car that didn’t come with the B&O system won’t work.
Rooz
Canada
2018 GT Convertible
Makes sense!
Thanks.
