Brembo Installation Guide
AlyourPal
Houston, TX
2015 GTPP
I've been searching here and can't seem to find it, though I know I've seen it. Would someone mind posting the installation guide for the six piston Brembo brakes on the GT performance package.
Thanks
jacknifetoaswan
Charleston, SC
What specifically are you looking for?
Remove old stuff, install rotors, install calipers and pads, torque bolts, connect brake hoses, bleed brakes.
JR
AlyourPal
Houston, TX
2015 GTPP
Sorry, just changing the pads. Simple I know but someone had the actual Ford service guide and it was handy. Can't find it through searching now
jacknifetoaswan
Charleston, SC
It's easy. Just pop the two pins out, remove the center bolt (watch that the cover doesn't pop into your eye), then use a set of pliers to remove the pads. Use a pry bar to push the pistons back into the bore (all six), then insert the new pads after lubing them. Re-insert center cover, pins, and bolt. Have a beer.
JR
timd38
Hudson WI
GT/CS C6 Corvette
JR
Hour tops.
Make sure that the beer is cold.
