Braking Performance Data Needed: 60-0 / 100-0
50 Deep
Signature Wheel Ford Rep
Gold Sponsor
Sacramento, CA
www.signaturewheel.com
2017 GT350R
Gents,
Looking to acquire some data. In your track apps you can do 60-0 and 100-0 brake performance testing. The car will give you the results after, and then the data is also stored if you go to view results.
Can you guys snag a pic of your test results and post it? Along with this info:
  • Tire
  • Wheel
  • Pad compound
  • Rotor Type (OEM or other)
  • Road Surface Type
  • Temperature
Thank You!
lonegunman
Eastern Washington
2019 GT350
I did my break in for the brakes from the manual then tried a few hard but not hitting the ABS stops. 60 to 0 mph in 98ft max, 1.22g max deceleration.
The brakes are awesome stock. I like good brakes and learned to drive in the olden days before ABS, automatic braking and child proof brakes.
Temps were in the 70's, I had the stock 2019 tire and wheel combo with Sport cup 2's. Road surface was asphalt and or chip sealed asphalt on an all but empty state highway between two small towns in the middle of nowhere.
oldbmwfan
Chicagoland
2017 GT350R
Different road surfaces and temperatures will likely cause a huge range of results, so would be good for people to at least post ambient temp and whether it's sunny or not. Hard to draw conclusions on anything that isn't same car, same day, same location.
50 Deep
50 Deep
Gold Sponsor
Sacramento, CA
2017 GT350R
Sweet. What did you have on the car? Wheel and tire wise?
Good point! The more data the better
