jbailer
I was answering Ebm's question which is different. I actually have the same question you do. Since I now have an open intake, I hear it even more and it's annoying. I don't know why they just bleed boost steady like that for so long.Yea I read up about all that before I got my adapter (not full on valve) luckily. I wasn't wondering about A/F as much as I was just pointing out a specific situation Ive noticed. Let me explain better:
I'll be cruising down the highway at let's say 75mph in 6th gear with cruise control running (for this example it's always running unless noted) and it's all basically flat here. After a relatively brief period of time, let's say at most 2 minutes, I will hear my factory valve (which is computer operated) begin venting and stay venting until there is a significant change in load (ex car has to speed up to go up a hill or start engine braking due to going down a hill, or I manually have applied significant throttle etc). I have heard this behavior continue for at least the length of a song.
Now my questions were if anyone knows definitively why this is happening and if a mechanical (pressure operated) BOV would/does exibit the same behavior?
Now I was speculating that a mechanical BOV would not exibit the same behavior since it's based on the pressures which are partially controlled by the throttle. This speculation is based on speculation that the prolonged factory blow off is a fuel saving engineering measure, which I based on a guess that the ECU vents the blow off valve (in my explained scenario) so less air is going to the engine so that it has to use less fuel and still meets ideal AFR. I have other educated guesses to back up my speculations and will gladly try to explain further if you want.
Apologies for my prolonged rambling, I am very bad at explaining my thoughts to others and it's a life skill I am constantly working on. Also I tried to write this explanation is a way that anyone who comes along would understand. :cheers:
I was thinking the opposite, I thought if they DIDN'T bleed the boost off steady like that they could use that air and I could give it even less pedal. It would be interesting to understand though.
