Doctor Fishtail
Please put me on pre order list. This will be the best bar on the market. Placing bets on how long it will take for the competition to copy. BMR leads the rest follow.
Thing is, I'm seeing a ton of folks running the 35mm on the stiffest setting. 38mm may allow folks to keep it the middle and allow one additional bump in stiffness if you desire it.I'm sure it will be of the best quality but wouldn't a 38mm front bar cause gut-wrenching understeer if it's the same wall thickness as the 35mm.
I am running the thickest bar on the market at moment. Hotchkiss 36.5mm But I am also installing coil overs and am concerned strut will rub. I have the BMR end links (quality pieces I might add) which have grease fittings on them which should make things tighter/closer to strut. Again Kelly put me on pre order list. Can you give us a good ballpark release date?what size is their current front bar?
Is a matching rear sway on the works too?And yes, it's a beast.
We have many racers who want a bigger bar....and we have also found the need for more bar rate on our development car.
The aftermarket bars for the rear are more than sufficient. You don't want to big of bar in rear. At least I do not.Is a matching rear sway on the works too?
Nope.Is a matching rear sway on the works too?
Keep up the good work.#BeastMode
I think it would look better installed on my car ;)#BeastMode
The bigger the bar the softer the spring, which leads to a better handling car.I'm sure it will be of the best quality but wouldn't a 38mm front bar cause gut-wrenching understeer if it's the same wall thickness as the 35mm.
