No, I sprayed them with a pressure washer prior to listing. Lots of undercarriage grime. The power coating peeled off the edge.did you need to grind the edge?
you used the outer hole on one and the inner hole on the other?
I was super curious also, so I took a closer picture. It looks like both lockouts show wear in both holes. I tried several different configurations, so I suppose that makes sense.did you need to grind the edge?
