BMR Tech Tip: Clock those bushings after lowering your S550!
Status
Not open for further replies.
kz
West Chester, OH
Mustangs & F150
No, you don't have to clock spherical bearings. But I would like to get a clarification on this as well. At which locations does the PP1 package come with spherical bearings instead of bushings?
Not enough of them that you don't have tighten fasteners at ride height - one of the RLCA inboard mounts (don't remember which one but other one has a bushing that Steeda / BMR has replacemement bearing for), toe link on the inboard (subframe mount) and tension link in the front - totally off my memory so might have messed up locations - but - since it still have bushings left, they need to be tightened at right height.
shadowx
Missouri
mustang gt premium 2019
do I need to clock the bushings if I have FP struts shocks and BMR handling springs (as it's not a big of drop)?
Bulldog9
NW Kentucky
2020 Bullitt, 2017 Tundra TRDPRO, 1976 Porsche 912
I'm lowered, but have no issues with weird noises or mismatched ride height, but the next time I have the car on the oil change lift I'm going to do this. A 3/4" drop will not create a huge preload on the bushings, but hey, why not..... Best to have the bushings unloaded at rest. With suspension dropped or raised, the bushings are always under tension, and have a minimal spring effect.
I replaced the pressed in suspension bushings in my 911 with spherical bearings with spherical stainless and derilin bushings, but it is not a daily driver. 5 years and 20K miles and they are good.
FWIW, I also had an E36 M3, and that car did NOT have spherical bushings.
TrackMustang
SoCal
2021 Mustang GT
Here is a list of torque values I've collected and summarized for myself while doing my build. I'm willing to keep this first post updated if people would like to list additional info and any corrections.
I make no guarantees they are correct since they came from multiple places.
Front Suspension
BMR Camber Bolt (18mm / 21mm): 125 ft/lbs.
Factory Upper/Lower Strut to Knuckle Bolt (21mm / 24mm): 184 ft/lbs.
Upper Strut Mount Nuts x 3 (15mm deep): 46 ft/lbs.
Strut End Bolt (Do not remove without compressing the spring) (21mm): 76 ft/lbs.
Brake Caliper Bolts (15mm): 85 ft/lbs.
Sway Bar End Links (18mm / 17mm): 85 ft/lbs.
BMR Sway Bar End Links (19mm / 14mm): 85 ft/lbs.
Front Sway Bar Mounts (18mm):
BMR Sway bar Mounts (10mm allen):
Front Lower Control Arm (24mm): 184ft/lbs
Front Lower Control Arm Nut to Spindle: 85 ft/lbs.
Rear Lower Arm to Frame: 184 ft/lbs.
Rear Lower Arm Outboard Nut to Spindle: 85 ft/lbs.
Cowl Extension (Upper K brace): 26 ft/lbs.
Strut Tower Cross Brace (15mm deep): 41 ft/lbs.
BMR Front Subframe Chassis Brace Rear Bolts (1"): 100 ft/lbs.
Inner Radius Arm Bolt (24mm):
Tie Rod to Spindle (18mm):
Steeda Extreme G-Trac Brace Front (10mm allen): 60 ft/lbs.
Steeda Extreme G-Trac Brace Rear (22mm): 60 ft/lbs.
Front spindle/hub nut: 251 ft/lbs.
Body/General
Oil Drain Plug: 19 ft/lbs EB+V6: 20 ft/lbs.
BMR Jacking Rails (15mm): 63 ft/lbs.
Lug Nuts: 148 ft/lbs.
Front Exhaust Clamp: 35 ft/lbs.
Exhaust Hangers: 18 ft/lbs.
Windshield Wiper Pivot Arm Nuts: 26 ft/lbs.
Negative Battery Cable: 44 in/lbs.
Transmission Cross Member (18mm): 85 ft/lbs.
BMR Driveshaft Loop (3/8"): 40 ft/lbs.
Front Belly Pan (7mm):
Differential Drain and Fill Plugs: 25 ft/lbs.
Water Pump Pully: 18 ft/lbs. EB: 177 in/lbs. V6: 18 ft/lbs.
Rear Suspension
Front Inner lower control arm bolts (24mm): 166 ft/lbs.
Rear Inner lower control arm bolts (24mm): 184 ft/lbs.
Outer control arm bolt (21mm): 203 ft/lbs.
Shock to Upper Shock Mount Nut: 22 ft/lbs.
Upper Shock Bolts: 66 ft/lbs.
Lower Shock bolts (15mm): 35 ft/lbs.
Main Cradle Bolts (21mm): 129 ft/lbs.
Front Cradle Bracket Bolts (13mm): 41 ft/lbs.
Rear Sway Bar Mount (13mm): 24 ft/lbs.
BMR Rear Sway Bar Mounts (13mm): 24 ft/lbs.
BMR Rear Sway Bar Thrust Washers (3/16" allen):
Sway Bar End Links (15mm / 18mm / 6mm allen): 85 ft/lbs.
Stabilizer Bar Bracket Bolts: 52 ft/lbs.
BMR Sway Bar End Links Jam Nuts (19mm):
Rear Swaybar Endlink Brake Hose Mount (10mm):
Vertical Link Upper Bolt (15mm): 76 ft/lbs.
BMR Vertical Link Upper Bolt (19mm): 81 ft/lbs.
Vertical Link Lower Bolt (18mm): 129 ft/lbs.
Toe Rod Inner Bolt (18mm / 21mm): 129 ft/lbs.
Toe Rod Outer Bolt (18mm): 129 ft/lbs.
BMR Toe Rod Inner Bolt (22mm x 2): 129 ft/lbs.
BMR Toe Rod Outer Bolt (22mm): 129 ft/lbs.
Camber Arm to Knuckle: 76 ft/lbs.
Camber Arm to Subframe: 85 ft/lbs.
Rear Brake Caliper Bolts: 24 ft/lbs.
Bump Stops
Bump stop trim dimensions for lowered cars pictured below. FRPP Bump stops are identical (same durometer as well) to the factory ones other than cut down. Save money and either cut your originals or order factory replacements to cut.
Alignment
Factory Spec
Front - Camber: -1.03 Total Toe: 0.00
Rear - Camber: -1.50 Total Toe: 0.23
Ford Performance Spec
Front - Camber: -1.55 Total Toe: 0.00
Rear - Camber: -1.98 Total Toe: 0.23
Any chance you have the torque specs for the 15mm bolts on the transmission mount? I see you have the 18 but I have to take the whole mount off…
Status
