Bleeding brake help. hissing noise
Keeffa
australia
keith
ford mustang 2018 gt
You don't need to have the engine running to bleed brakes. Yeah you can get some different noises while bleeding. You should use about 2 liters of brake fluid.
Have you got a good firm peddle. If so job done.
I don't use anything fancy, just a hose in a jar. Hose is a good fit on bleeder and other end stays in fluid in jar. Loop hose from bleeder up to a hook on top of car spring back down in to jar. Open bleeder half turn pump peddle about 10 times per caliper, both sides at front, Keep reservoir topped up.
Have fun.
