Bama Tunes bad rap....
LethalPerformance
Fl
2020 Shelby GT500 CFTP, 2021 Whipple'd F150
so what's your knowledge on injectors, I am interested in going with 47lb injectors... I see the 07-2012 GT500 uses EV14 injectors same as a 18-22 mustang. Which those injectors are 47 injectors, I can get the Bosch injectors for 24$ a piece ... just wondering if it will work
The injectors on the 07-14 GT500 are the short 48mm injectors where the coyote uses 60mm injectors. So you don't want to go with the ones for the GT500. I would recommend either the LU47's or the Lethal Performance LP52's. Both are the correct height for the coyote and are easily tuned by the top tuners in the industry.
https://www.lethalperformance.com/ford-performance-ev6-47lb-high-impedance-fuel-injector-set.html
https://www.lethalperformance.com/f...mm-high-pressure-fuel-injectors-8-pieces.html
