StealthStang
- Oct 6, 2016
- South Africa
- 2016 Roush Ecoboost (NX2)
It would have taken too long to get the part. I already had a Kicker front row and it has that functionality built in, so its already working like you described, tapping the blue/green wire and sending it to the front row which accepts a 6V turn on.You can not order a PAC TR-4 from anyone here in the states?I would try and get one wired in if you can.You want the processor to come on first,then the amp.The audison has a in and out turn-on lead to do just that.You could leave the ford amp plugged in and just tap off the blue/green to the PAC.Then feed it to the audison,then to your amp.That should turn it all on in the proper sequence and eliminate any noises.
The Audison works with 12V or input sense only, so it would need the PAC but that would have taken several days maybe weeks to get here. This issue was far too annoying to leave it for that long, so i settled with the Front Row it seems to work well.
