Copperhead73
- Oct 13, 2019
- Knoxville, TN
- Derrick
- 2019 Mustang GT Premium Convertible PP1, A10, Mag, B&O, A/E, S&S
It has been doing this pre-any sort of mod. I probably noticed around 1k miles, with 2500 on it now. I think it has gotten a little louder, but not by much. I do have the sound tube irrigation valve mod, but it did it before that, and does it either open or closed...I was thinking it was the tube at first...not so sure now. I don't think it's a wheel bearing because it doesn't change pitch with speed, and doesn't do it all the time, or even that often. It is a 2019 GT Premium A10. I changed tires, but it happened before and after the change.
I don't think it is the brake dragging either. I can't tell if it happens when the tranny shifts, but I have put it in neutral while it is happening and it doesn't stop it immediately. Is it the tranny? I put this description in the vid.
It can happen either when the car is warm or cold. It seems to happen when either accelerating or decelerating, and is typically only noticeable at slow speeds Under 30. I've threw the car into neutral while it is doing it, and it continues. You can sort of feel a slight vibration when it happens...almost like a cell phone on vibrate, but the pitch doesn't change with speed. It seems to come from in front of the driver. Any ideas?
You might have to turn up your volume a bit to hear it. Thanks for looking (listening)? The sound begins immediately upon video play, stops at 1 second, starts again at 2 seconds and lasts til 4.
