Hello -- I'm wondering if anyone has personal experience with either the Steeda braided, or Ford Performance clutch line upgrades? Have any of you on occasion had your clutch stick at high RPM?
I have experience installing both brands and I run the ford performance one. I haven’t experienced any clutch sticking from stock clutch to dual setup that I’m running now. I also run Castrol SRF brake fluid which can have a beneficial factor.
I installed the steeda line but haven't had any high rpm sticking before. It's been cool weather since I installed mine but I'm hoping it helps with a "mushy" or slightly sticking pedal during longer highway/interstate trips. What I have already noticed are much more consistent engagement and release points, along with better feel.
Install was easy and only lost a few drops of fluid, literally. Pull the topside loose first and cap it. The vacuum will retain most of the fluid when you pull the bottom.
Bleeding on the other hand I thought my leg might eventually fall off! Then it still needed more bleeding after a quick few miles.
Thanks folks - that’s all helpful. Still trying to determine if it would be worth the additional $200 for the FRPP, or if the Steeda is helpful enough. There’s an SVE one that looks similar to the Steeda from LMR, but would expect that one to be disappointing - I’d rather just do the job once, and be happy with it.
