WCKD350
- Dec 1, 2021
- Laguna Nigeul CA
- Sina
- 2017 GT350 / tricky performance E85 tuned
As many of you know, GT350s are notorious for active exhaust issues — burnt harnesses, stuck valves, failed actuators, you name it. I’m running a pretty aggressive setup: catless ARH longtube headers and a Corsa Xtreme valved cat-back, still using the OEM actuators and harnesses.
Last year I already replaced both actuators and harnesses (OEM), which gave me about 10 months of working valves. Now I’m back to square one:
I’ve considered pulling the mufflers to clean/lube the valve flaps, but that means another $200+ at a shop with no guarantee it’ll fix it. I can’t run open valves 24/7 due to neighbors and local police, but replacing actuators every year is getting ridiculous.
Has anyone figured out a reliable long-term fix for setups like this? Especially with headers/catless systems? Maybe:
Appreciate any feedback — just trying to keep the active exhaust functional without living in a shop.
- The car doesn’t throw any errors — no “Exhaust Mode Not Available” or “Drive Mode Not Available” messages
- I can still toggle between modes, but:
- The valves are often stuck closed or won’t switch back after opening
- Sometimes they briefly work, then get stuck again
- On cold starts, the car defaults to quiet mode and sometimes stays stuck there the whole drive
- I don’t hear any clicking or motor noise from the actuators when switching modes
- I just fully charged the battery with a CTEK 7002, and while it helped with cold starts, the valve issue still persists
- I’m seeing inconsistent voltage while driving: ~12.6V under light load, jumps to 13.6–14V at 2.5–3k RPM, which makes me wonder if low RPM voltage or alternator behavior is affecting valve function
- Stronger aftermarket actuators?
- External valve controllers with better reliability?
- Custom valved exhaust that handles soot/heat better?
