315/35/20 uh oh maybe ran into some problems
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
Holy bigfoot tire lol
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
I thought I had the sportlines, I keep getting them confused. I have the pro ones but will that all still apply?
Yes do the drop take it to a alignment shop make sure u have about -2 degrees of camber for the rear and those 315 tires will fit fine.
NewSVO
Guard boost premium 6mt
You're the best! I appreciate all of the info man :cheers:
Message me, need some wheel info anyway!
Laztug
Wanna run dyno slips bro?
COTUS
Calling out OKC #1 spot after axle back install.
315/35 mpss issues!?
Not here.:D
Wolfman625
Charlottesville VA
2015 Mustang GT in Deep impact Blue
You should fit. Guy around hear has 275 up front and 315 rear lowered 2 inchs no cutting or any thing
Sixth
A
Prius
resting a larger tire against the smaller rears while on the ground will not tell you anything about fitment...except give you a false illusion that it wont fit...
Todd15Fastback
Atlanta, GA
Todd
2015 Mustang GT PP Fastback
Not here.:D
What springs are you running? Looks good:D
Edit - just saw your build thread. Steeda springs FTW!! Your car looks freaking amazing. Did you have the camber set at -2 your rears as well?
Anthony
To posts or pm's
Can't respond
315/35/20 nitto invo's on a 10.5 forgestar wheel from Jason @ get your wheels.com
NOW they clear and don't rub. Cradle alignment is a problem on these cars. Bmr is coming out with a fix for it. But for now it's not easy to aling. I'm lucky as watson built a jig to aling the cradle. Gotta drop the cat back though.
Mine was shifted 5/8" to the drivers side.
NewSVO
Not here.:D
Looks good, won't have to sell them then!
275 is too big for me at least on fronts, 255 is plenty but that's good to hear!
I see, stupid me.
I was gonna go with the invos even because I live in FL but for a daily it's just a waste. I did want 315s because I know at some point I'll be upgrading the turbo in this thing and they look badass.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Nitto and Toyo sit slim compared to the MPSS so the fact we can fit a 315 MPSS that sits wider then its listed shows we got some serious room in the rear of these badboys.
Laztug
COTUS
275s are perfect IMO!
Here is a shot before the drop.
Ashpian
Savannah, GA
Scott
2021 GT500
What does aligning the cradle involve and when exactly does that come into play? Is it a job a normal alignment place can do or do you need more of a performance type shop?
Thanks
Anthony
To posts or pm's
Can't respond
I don't believe a normal alingment place can handle it yet.
Watson made a fixture that requires dropping the cat back to align
BMR has a fix coming out pretty quick I believe. Pm or email kelly to get him to release it!
I got mine close by eye and string hanging off the fender.
I could do it at a alingment shop. But I bet they won't loosen the cradle from the body to get it.
SC_Sport_Pilot
Trenton, SC
Gene
2014 Ford Edge; 2015 GT PP, 06 F350 Dually
Anthony,
Can you describe the cradle alignment issue? What would one look for on
a stock PP car? Is there something specific we can look at and perhaps talk to
Ford. If this is what I think you are talking about, then our cars would "cat
walk" or in other words the back ends would not track in a perfect line with
the front of the car. Is this correct?
Thanks!
