20x10.5 Et +38 wheel recommendations?
allgripnoslip
Ca
'15 GT PP
I'm trying to find a specific size wheel, 20x10.5 ET +38 to fit my '15 GT, but I have only found 2 wheels that exist in that specific size. "Advan Racing GT" and
"Spec-1 Monotec SPM-75" wheels. The Advan's are superior to the Spec-1's in every way, but I'd rather have something lighter weight and maybe better looking. (I like the HRE FF01's look)
Does anyone have any recommendations for 20x10.5 +38 wheels? A 20x10.5 +37 would be acceptable also.
Any online places I should try searching?
Thanks.
Shouldhavegotthegt
Phoenix
2016 Magnetic GT 2014 Ram 1500 RCSB 4x4
I've seen guys running Niche wheels 20x10.5 et30 with no issues. Super flush. So you've got room a on square setup to look at other brands. I think et35 is just about perfect on a 10.5 wheel.
allgripnoslip
allgripnoslip
Ca
'15 GT PP
Not with 305/30/20's in front. My front tires are threading the needle between my fender and coilover. +37 or +38 will keep my 305's away from my springs while still barely staying under my fender on compression.
Shouldhavegotthegt
Phoenix
Ferrada and Verde Axis makes a 20x10.5 et38
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
The 10.5 you want to run as close to a 30 as possible so that Et 38 plus a 5 mm worst case upfront.
allgripnoslip
allgripnoslip
Ca
'15 GT PP
Thank you. That's exactly what I was looking for. Those Ferrada's look perfect (other than price) but I could only find the Verde's with +25, +27, +30, +42 and +45mm offsets.
A set of Ferrada FR2's or FR3's might be in my future.
Right now I'm running a 20x10.5 +45 with a 7mm spacer. I'm wanting to remove the spacer.
FlowForm_Wheels
Vista, CA
www.hrewheels.com
HRE Wheels
Mustang
(I like the HRE FF01's look) Thanks.
Hey if you like our wheels we do have a 20x10.5 ET45 fitment. Just slap on a 7-8mm spacer and call it a day! You get the wheel style that you like with minimal hassle :)
If you want to go REALLY light, then I have even more options to consider too.
EDIT:
Sorry bud, just saw this part after I commented.
allgripnoslip
allgripnoslip
Ca
'15 GT PP
Lighter is always better so of course I want to go really light. The only problem is it makes my wallet really light.
Idealy I'd like to be under $500/wheel but could stretch to $600/wheel if the weight was better.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Ya you should be good then easily. Im a flush fit type of guy so the ET 30 always has been a good setup for me.
aex90832
Resident Comm Guy
Metro East, Illinois
2019 Shelby GT350, 2016 E350 Wagon
et30?
Are you saying 20x10.5 ET 30 will be fine in the rear and not poke out from the fender (assuming with a 305/30R20 tire)?
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
2016 Shelby GT350 Tech Pack #G5531 Avalanche Grey
I've done a bunch of 20x10.5 ET 30 applications it works just fine, dead flush min poke, however widest tire being used without using a ton of camber is a 275/35/20 and or a 285/35/20
