20x10 +40 with 305's square set up?
greggotanafro
SATX
2017 LPF Mustang GT
BLUF: Can I run Niche Verona M168 20x10 +40 wheels with Nitto N555G2 305/30/r20 wheels on a stock suspension set up with no modification/worry?
Another question while we're here: Why cant you run the same size tire on staggered wheels? like 305s on a 20x9/20x10 set up?
Got lost in the sauce trying to read and understand past threads on the topic but Im needing to buy some wheels and tires. I'm a little under 700hp so I'm wanting to go as wide as possible with a square set for cost efficiency and grip. Is it feasible to do that with the above set up? Or is there another wheel/brand set up known that I can achieve this?
Thanks in advance!
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
2016 Shelby GT350 Tech Pack #G5531 Avalanche Grey
No you need the front to have a lower offset for proper strut clearance.
305 on a 9" is too wide and will buldge.
You can if you desire but it would be much better to do a 285 on this specific wheel then overdo and use a spacer.
other then that you can use a different wheel for instance use a proper size sticky tire and or square wheels staggered tires for proper grip on the back.
Let me know if youd like any help.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
He meant 305 on a 10" is too wide. (not 9")
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
Middle section brotha says why cant we run the same tire on staggered set of wheels. :cheers:
