2019 Steering Wheel's upper right switch inop
thunderstrike
Montgomery, AL
2019 Mustang GT Premium 6 spd
Upper right switch is inop, unable to see tire pressure and other vehicle settings. I replaced the clock spring, then installed new upper right switch, still does not work. Any ideas?
SHOdaddy68
Washington State
Daryl
2015 GT PP Premium w/Recaro
Check your connectors to make sure there are no bent/damaged pins or wires that got pulled slightly out the rear.
thunderstrike
thunderstrike
Montgomery, AL
The right upper switch started working after having disconnected the battery overnight and charged it.
Uncertain if replacing clock spring and upper right switch were necessary. When in doubt disconnect the battery to reset CAN bus upon installing new parts.
