2018+ PCM or BCM PATS delete it is impossible?
The RedMus
Miami
Diego Certified
2015 Mustang 50 Year Edition
i have another post about my swap engine from ecoboost 1st phase to Coyote gen 3 and i did not get the matching PCM + BCM + Keys fron the donate car, so i am basically stuck 3 months ago trying to re programming the computers or avoid the PATS system with no luck! since i could not found another donate car to get the PCM + BCM + Keys so far, the only solution is to get one of those swap harness + PCM to run the engine by alone! the problem with it is that i will lost the communication with the car loosing the cluster info like RPM, Speed , ETC! but the car can be usable again!! so the question is, anybody knows something about to re-programming PATS on a not matching VIN number car or how to get work the cluster using one of those swap harness + PCM stand alone kit? this will be a temporal solution until i could found a donate car to get what i need! any ideas?? this computer program is impossible to hack or modified? even if i bought brand new computers from Ford how can i get this works again?
