2018 GT350 front splitter U clips
Klenkmeister
Richmond, TX
Eric
2018 Shelby GT350
Anyone know where I can find the 12 u clips that go on bottom of splitter that the torch screws go into. I ordered a new splitter and Ford gives you all hardware except the 12 U clips. I went to Ford and there system shows the wrong part number. I’m short 1 clip. I bought car used and whomever had it previously had apparently taken off the splitter and likely lost one of the U clips as the rigged that one and it was not screwed in all the way bc the clip they used was not metric. It’s metric and I’m having a helluva time finding them. Any help would be appreciated. It appears to be 10-12 mm from center hole to body
Davesvt2000
Massachusetts
2021 Mach 1
Take one to an industrial hardware store, or specialty store like Fastenal.
They should be able to match it up pretty close.
Or do what I did and simple bolt, lock washer, and nut instead. Worked fine and no one will ever be under the car to know.
