2018 and rear window
sebounet
montreal
2018 conv gt auto, var exhaust,shaker, safety pack
I noticed when the roof is open i can t close the rear windows only the front.
In my 2016 i was able to do both indepently.
Can someone with a 2018 tell me if it s the same for you
CVCashmere
South Jersey
Carl
15 GT Vert w/Steeda lower brace, PP sways & susp
That sounds like a problem. So when you drive down the road, the rear windows are always up?
The commercials show the windows down!
Dealer time.
CVCashmere
sebounet
sebounet
montreal
Dealer time.
CVCashmere
No the rear windows are down, i can t rise them with the top down
jtmat
DC/MD/VA metro
Vert turbo!!!!
Take it to the dealer... they go up and down with the top up or down. Sounds like some switch has malfunctioned.
wanted33
Down South in Dixie
Jim
2018 GT Convertible, 2006 GT Coupe
I agree. As bad as those words are to swallow, it's a trip to the dealer that's needed. Good luck, I hope it's a simple fix.
BTW, will the rear windows cycle up/down with the top up?
sebounet
sebounet
montreal
I checked today, and i think it was my mistake. May be i just begun to close very slightly the roof and stop for whatever reason (nice woman passing by), and forgot and try to close the windows.
Today in my garage everything was correct. (no distraction :) ). I just press the button to close the roof like 0.5sec and can t close the rears windows. press it to open it and was able to do it.
I will never look nice women in the future , promiss... :headbonk:
By the way , i saw that if the windows don t go up because the there are a little stuck or stopped by something, you can disangage the anti pinching feature to force them to go up.
Manual Override
The rear quarter window switch will not operate when:
• the convertible top is moving • the convertible top is not completely up or down.
The rear quarter windows can be manually raised if the switch does not operate when the convertible top is completely up or down.
The following procedure must be performed within two minutes:
1. Switch the ignition off, then back on.
2. Press the rear window switch down three times.
3. Switch the ignition off, then back on.
4. Pull the rear window switch up and hold it for three seconds. The rear windows will begin to start moving up.
