2017 Mustang gt Running Lean need help
Burning Clutches
fargo
Terry
2017 mustang
Modifications:
Fic1000 injectors
Ess supercharger g2 with 110mm pulley
Lethal performance level 2 return fuel system
the car starts to lean out at about 4500rpm and I cannot figure why it’s happening. Also I have my regulator being boost referenced and set to 55psi base pressure.
mejohn50
Intergalactic Snail
United States
Mitch
slow junk
What's fuel pressure doing when this happens? How are you determining it's lean?
Also, have to ask the obligatory question...what has your tuner said about it?
Burning Clutches
fargo
Terry
2017 mustang
The fuel pressure is stable at 55psi and my tuner sent me a picture of my fuel tables in all red
horsepower addiction
Arizona
Nate
s550
Ok your pressure should not remain stable at 55 there’s a boost reference for a reason. If you add 10 psi of boost you should get 10psi more fuel pressure. Have you logged fuel pressure and fuel pump duty cycle ?
