GT 2017 Mustang GT PP Aluminator Procharged
san diego
chris
2017 Mustang GT PP
Asking $50,000 obo
San Diego, CA
2017 Mustang GT Performance Package in magnetic gray with 11,300 miles and 4,300 miles on the new motor. The engine was built by Addiction Motorsports. Tune done by Rob Shoemaker at Palm Beach Dyno with a 4.24” pulley. Hasn’t seen the dyno since the new tune. Previous tune made 971 hp and 731 tq at 17.5 psi with a 7.38” pulley. Car has never been raced or seen the track.
Engine
-Aluminator Long Block N/A 11:0:1 Compression
-ATI Damper
-Comp Cam Stage 2 Blower Cam
-GT350 Intake manifold with adapter to stock GT throttle body
-MMR IMRC Delete
-MMR Oil pump/crank gear
-MMR Billet Chain Guide Kit Fixed
-MMR Billet Secondary Chain Tensioner Bracket
-MMR Billet Secondary Upper Chain Guide
-MMR Secondary and Primary Chain Tensioners
-Procharger Stage II Kit F1A-94 Head Unit (4.24” pulley 20psi)
-Fore Innovations Fuel System Level 4 Dual Pump 1200+hp
-Injector Dynamics ID1300X
-Kooks Long Tube Off-Road Header True 3” to Corsa X-pipe
-Corsa Sport Cat Back
-UPR Oil Catch Can
-UPR Crankcase Breather
Transmission
-DSS One Piece Aluminum Driveshaft
-McLeod Twin disc Clutch
-McLeod aluminum lightweight flywheel
Wheels And Tires
-Weld RTS S77 17x5 Front
-Mickey Thompson Sportsman Front Runner Tires 28/6R/17
-Weld RTS S77 17x10 Rear
-Mickey Thompson ET Street S/S Radial 305/45/17
-Baer Drag Brakes front and rear
Front Suspension
-Koni Yellow Adjustable Shocks
-BMR Drag Springs
-BMR Caster Plate
Rear Suspension
-Viking Double Adjustable Shocks
-Steeda Shock Mount
-Steeda IRS Alignment
-BMR Drag Springs
-BMR Aluminum Diff Insert
-BMR Cradle Lockout
-BMR Delrin Lower Control Arm
-BMR Delrin Vertical Links
-Whiteline Adjustable Sway Bar
Interior
-Fathouse Fab Driver Side Seat Bracket
-Kirkey Race Seat
-GT350r Rear Seat Delete
-Brey Krause Harness Bar
