S550Felipe
- Aug 4, 2020
- Los Angeles , CA
- Felipe
- 2017 Mustang GT
Dude ! Thanks ! The clutch pedal switch wasn’t even connected. It’s weird because the switch wasn’t hanging down, instead it had a zip tie holding it. I wonder if the previous owner did this on purpose ?? Anywho ! Thank you !You may have a problem with the clutch pedal switch, which detects the position of the pedal.
Normally, this switch detects the end position when the pedal is fully pressed in.
Since this switch is a condition for ignition, the START button will only react when the clutch switch is closed (pedal fully pressed).
In your case clutch switch may be closed before the pedal reaches its final position, but not any more on the final position itself.
Therefore, the ignition only starts when the START button is pressed and the pedal passes the switch-on point for a moment.
You can test this by sequentially pressing the START button while slowly depressing clutch pedal (take care to be in neutral gear during this test+brake is applied).
If on some position of the pedal engine will ignite, you have the problem with the switch mentioned above.
