Sold: Tennessee 2015 Mustang GT - RPG Built 5.2 w/ Whipple 1k WHP
Status
Not open for further replies.
DarkSubRosa
GTFO_0027
Nolensville, TN
2015 Mustang GT / 2023 GT4
I'm starting by posting here for sale. I need to make room in the garage for some new cars and I just don't ever really drive this anymore. 1022 RWHP and 789 ft-lbs of torque.
History:
Car was bought new, I'm the only owner. No accidents or stories. I sold the stock 5.0 and MT82 in favor of a new built 5.2 from RPG with a built TR6060 trans. This is a 401A car new. Extensive mods list below. Car is tuned for E85 only and the tires obviously can't hold the power if you are mashing it currently. There were no R compounds available in the sizes I needed at the time I bought tires and I don't drag race so I never bothered getting any others. No CEL. Starts and drives completely smooth and stock when cruising around thanks to Lund.
Asking $55k and open to negotiation with serious buyers. No trades.
Miles are around 12,500 currently and I still drive it some so they might slowly go up.
Wheels/Tires
Vossen VPS-301 20x10 +30, 20x11 +48
Michelin P4S 285/35/20 & 305/35/20
Monster lugs
Suspension
Maximum Motorsports Camber Plates
Steeda Springs
Steeda Adjustable Toe Links
Steeda Front and Rear Sway Bars w/ Billet Mounts
Steeda G-Trak
Steeda Jacking Rails
Solid FRPP Rear Subframe & Differential Bushings
Steeda Adjustable Shocks
Steeda Billet rear shock mounts
Steeda Bumpstops
Steeda IRS Subframe Support Braces
Steeda Vertical Links
Steeda Rear Adjustable Upper Camber Arms
Steeda S550 Mustang Adjustable Swaybar Endlinks (front and rear set)
Steeda S550 Mustang Rear Lower Control Arm Spherical Bearings
Steeda Knuckle To Toe Link Bearing Assembly
Steeda Front Tension Links w/ Bearings
Steeda Bumpsteer kit
Steeda Front Control Arms w/ Bearings
Ford Performance Solid IRS Bushings
Ford Performance Solid Diff Bushings
Ford Performance S550 Mustang Rear Wheel Hub Kit w/ 3" ARP Studs
Ford Performance S550 Mustang Front Wheel Hub Kit w/ 3" ARP Studs
Performance
Whipple Gen 3 w/ 150mm TB
Corsa Sport Catback
Corsa Catless Headers
ARP Header Bolts
Reisch 170 degree thermostat
nGauge/Lund Tune (E85)
Watson Catch Can
Watson Battery Relocation
MGW TR6060 Conversion Shifter
Steeda Delrin Reverse Lockout Collar
Steeda Clutch Assist Spring
DSS Carbon Fiber Driveshaft
McLeod RXT
McLeod Lightened Steel Flywheel
ARP Flywheel Bolts
Triple Pump Fore Fuel System on 2psi Hobbs for Pumps 2&3
C&R Racing Engine Coolant Reservoir
Motor Work
  • 5.2L Short Block above plus New 2015+ Stage 3 Ported heads
  • ARP Head Studs
  • 5.2L Ford Racing Head Gaskets
  • MMR/Livernois Timing Chain Guides/Arms
  • New Ford Timing Components/Cam's
  • New Ford Oil Pump and Pick Up
  • New Ford Racing 5.0L Cross Plane Crank
  • Manley Platinum Series Pistons 11 to 1 CR
  • Manley H-Beam Rods with ARP2000 Rod Bolts
    - Cryogenically Treated -
  • Total Seal Stainless Rings
  • Clevite Coated Main and Rod Bearings
  • ARP Main Studs and Side Bolts
  • Fully Balanced and professionally assembled
  • TSS Oil Pump Gears and Timing Sprocket
  • Stage 2 Comp Cams S/C cams
  • Manley Valve Springs and Comp Cams Retainers
  • Gen 3 Stage 2 Whipple w/ Monster Heat Exchanger / 10 Rib
  • Custom brushed and copper powder coated housing
  • ID1700 Injectors
Tremec 6060
"Stage 2" 2007-2010 Ford Mustang GT-500 Tremec TR-6060 6 Speed Transmission. Transmission capable of supporting 1000+HP.
Transmission features
  • Integral Bellhousing
  • 26 Spline Input Shaft
  • 2.97 1st Gear Ratio, .80 5th Gear Ratio, .62 6th Gear Ratio, and Bolt On Flange Design Output Shaft.
Transmission has been upgraded with the following components:
  • Cryo Treated 1st thru 6th Gears, Synchronizer Sliders, Hubs, and Shift Forks
  • REM Polished 1st thru 6th Gears, Synchronizer Sliders, Hubs, and Shift Forks
  • Upgraded Brass Shift Fork Pads on 1st thru 4th Shift Forks
  • Upgraded Carbon/Sintered Bronze Rings on 1st & Rev. Gear
  • Sintered Bronze Rings used on 2nd thru 6th Gears
Exterior
UPR Gloss Black badging
Diode Dynamics Full LED Exterior Lighting w/ Switchbacks
SunTek Tint
CDC Roof Spoiler
VLAND 2018 Style Clear Tails (OEM Tails included)
Zombie's Orange Puddle Lights
Diode Dynamics RGBWA Gills w/ Gloss Black shroud
Diode Dynamics RGB Demon Eyes
Ford Racing Performance Rear Panel
RTR Upper and Lower Grills
RTR Grill Lights
RTR Side skirt extensions
RTR Rear Diffuser
Ford Performance OEM GT350 Track Pack Spoiler
Steeda Front Splitter
Trackspec GT4 hood vent kit for stock hood - Not installed
Interior
Diode Dynamics Full LED Interior Lighting
WeatherTech Mats (Stock Mats included)
Anarchy Motive Shift Knob
GT350R Steering wheel
JPM Coachworks Door panel inserts
JPM Coachworks Knee Pads
JPM Coachworks Shift boot
JPM Coachworks Console Cover
JPM Coachworks Handbrake boot
MMD Flip Up Start button Cover
GT350R Rear Seat Delete (I have all of the stock back seat components to revert back to having seats.)
Watson 4 Point Cage (Powder coated the same color as the blower, wheels etc. just not installed)
Crackerjack17
WV/Maryland
2017 GT PP
Someone better beg, barter or steal and buy this immediately. This should go for over asking. Nice car.
SheepDog
Colorado
Dax
Iconic Silver 2022 MACH 1 HP
Courtesy bump. This thing is nuggin futz
Nawsad123
Everett
Bonez
2017 Mustang GT
Yea....for 55k nothing, i mean nothing is touching this. Bumping to support OP. Hell of a build.
stannypack
NOVA
2022 Mustang GT
gahdamn
tangermean
Houston
Shelby Gt350, 68 Coupe
WOW! I might have to look into selling my 350! this thing is nuts! I love the door cards, looks like they are now out of business sadly.
DarkSubRosa
DarkSubRosa
GTFO_0027
Nolensville, TN
Yeah he went to work for an OEM so that's why he closed down. That was years ago. I first met him through the S2000 Community where he first started doing the interior upgrades so glad I caught him for the Mustang before he moved on. What year/options GT350 do you have?
tangermean
Houston
I have a 2019 with the comfort seats, no track pack or carbon fiber dash.
rolfe.oliver
St. Louis, MO
Oliver
1967 Mustang GT350 Tribute, 1971 Mustang Mach 1
Crazy this hasn't sold. Honestly, wheels may be limiting potential buyers since people don't realize how easy changing wheels are. I bet black or silver wheels would have this sold in a week.
DarkSubRosa
DarkSubRosa
GTFO_0027
Nolensville, TN
It’s a niche build. Most people who want this type of engine build, want an auto with slicks to drag race. A buddy who had a similar level of a build took 4-6 months to sell and he had black wheels. It’s just about finding the right buyer or getting exposure. Once spring rolls around it might go up on cars and bids if I haven’t found the right buyer.
rolfe.oliver
St. Louis, MO
Oliver
Totally agree. If I didn't just get my 350, I would be all over this for that price.
Status
