2015 mustang gt pp my color cluster swap
Heeroyuy17
Tennessee
Travis
2015 mustang gt
Hello I am new to this this is my first post but I have swapped my 2015 mustang gt my color cluster to a 2018 my color cluster for the halo and digital Speedo option, so far everything works perfectly except my rpm is not reading it doesn't move at all, I have tested with a gauge sweep and so the motor that moves the needle is fine, I have downloaded forscan and have my obd cable and have looked at every option I can find to try to correct it but I can not figure it out, Iā€™m assuming it has to be in the as build parts but Iā€™m very lost on that. So please if anyone has any idea on how to correct this help šŸ˜“
Pucklord
Royal Commission of Yanbu
Mustang GT California Special
Hey brah .. just saw your question and I run into the same issue when I install my 18 cluster. Check my post but anyway as I said I run into the same issue and I fix it by loading my ipc file from my stock cluster to the new installed one.
Pucklord
Also one of the issue I faced was the high beam indicator not displaying at the new cluster .. and found the solution here
