2011-2026 Ford 5.0 / 5.2 Engine Main Cap Puller / Removal tool
Mod Mustang Racing
California
www.modularmotorsportsracing.com
Worlds Fastest & Only 5 second Coyote
Ford Coyote Gen 1, 2 & 3 Block Main Cap Removal Tool Puller
MMR's Main Cap removal tool for ALL 2011-2024 Ford 5.0 / 5.2 Coyote engines is the best in the business. Our Billet Aluminum Main Cap Cradle is Made by MMR right here in our Camarillo, CA facility. Unlike other brands it will not damage, chip or scratch the fragile block Oil pan rail. Also, unlike the other brands, It works WITH or WITHOUT the crankshaft installed in the block. It is even compatible and designed to work with ARP main studs without removing them!!
NEVER USE SCREWDRIVERS to pry up maincaps, it will damage the register and render the block useless requiring expensive machine work.
Features:
FAST, EASY TO USE!!
Works with or Without crankshaft installed
Billet Aluminum Soft Jaw will not damage block or Main caps
Will Not Damage Oil pan rail like the dual prybar style pullers
Works with ARP Mainstuds installed - removal of the stud is not required!
Order now: https://www.modularmotorsportsracing.com/cart/index.php?main_page=product_info&products_id=1591
