18's really dont fit PP brakes
MustangCollector
NYC
Various vintage shelbys
tested quite a few wheels today with offsets ranging from 30-45 but that's not the issue the actual inner rim barrel does not fit over the caliper as it is HUGE.
just giving everyone an FYI
i had to buy 19 staggered Blizzaks today for the winter which sucks.
GetYourWheels
Santa Fe Springs, CA
www.GetYourWheels.com
Eddie
GT350R / Tesla Model 3P
It depends mostly on the wheel design/manufacturing process.
For instance, Forgestar confirmed that the 18" CF5s will clear the GT PP brakes. Because the wheel is flow formed, Forgestar is able to produce the wheels with thinner material on the barrel, which gives it just enough room to clear the GT PP brakes.
However most 18" standard cast wheels will probably have fitment issues
xXANCHORMONXx
SF CA
2016 GT350 Track Pack
xXANCHORMONXx
SF CA
Also does anyone know if the new mustang has the ability to change tire size on the center display?
jayman33
Fort Bragg, NC
Jason
24 GT
The inner barrel along with spoke design is whats going to determine if they fit. Right now we know that the Forgestar CF5's fit and HRE is making a set of 18's that fit as well.
Grimace427
NoVA
2011 Mustang 5.0
On this new chassis running 18s say 18x10 and 18x11 I'd need to run a 305/40 over a 305/35 for example?
Up front, when installing big tires you need to consider clearance with the strut's spring mount. I don't know exactly what fits.
You mean for speedo calibration? I seriously doubt it. You would likely need a tuner for that.
xXANCHORMONXx
SF CA
What a shame
Seems stock sizing is a 27 inch tall tire. On the 18 inch or wheel they are running a 50 series!
Anthony
Grimace427
NoVA
2011 Mustang 5.0
What a shame
Anthony
There is no such thing as '50 series'. The aspect ratio is tied directly to the width so a 235/50 has nearly the same height as a 285/40. For track use you can go with a shorter tire for extra clearance without any issue. Sure the speedo might be off but that doesn't matter much on a racetrack.
xXANCHORMONXx
SF CA
Ofcourse, I thought "series" was the correct terminology for it. I just meant that the 27 inch tall tire is what ford is using and in order to make the oem 18s work they used a 50 series tire to raise the height.
Grimace427
NoVA
2011 Mustang 5.0
The good news is you don't have to match the stock tire heights if you don't want to. I would wait for shops like Vorshlag to run some 18" tires on their cars to see what works best.
xXANCHORMONXx
SF CA
That would be nice, it would take out the guess work
