16" Wheels on Base Eco
SteedaGT
Orlando, FL
2016 Competition Orange Ecoboost
So my '04 is down at the moment and I wanted to test fit my ccw's again on the woman's '16. Low and behold, they fit with little or no modification.
These are setup for an '04 GT with an 8.8" and 9" ends (slightly narrower than a 99-04 8.8" solid rear. Fronts are 16x4.5 and rears are 16x11 on a 28x10.5. Total weight savings is 63.4 lbs.
No photos of the entire setup on the ground yet. My lugs from my '04 are too small for the larger studs of the '16 and the oem lugs are too fat for the ccw's. I need to find some open ended lug nuts with the quickness. The Steeda event is this weekend. Any suggestions?
Fronts fit with no modification. Literally bolted right on.
Rears needed a little bit of grinding on the calipers and a 1/4" spacer to clear my assembly bolts of the rims.
