dn1984
- Sep 14, 2019
- SF Bay Area
- 2018 Mustang GT A10 Premium
Got a weird problem. I'm on AED's E85 tune (well right now on the flex after having the issue) so I have very high pressure shifts in S mode. I was in Mexico the other day and did a couple back to back runs against a bike from about 60-140. On the second run I noticed it slipped or hung when shifting into I think 6th gear for a couple seconds. So I left off and slowed down to cruising speed, checked transmission temp and it was about 205 which is normal. Didn't think anything of it.
Fast forward to later that night and I was still in Mexico but this time against a 5th gen heads/cam Camaro SS. This time I did 3 back to back runs around the same speeds and again got the delayed shift on the last one. Once again, slowed down to 70 and cruised on the highway for about a mile then checked my trans temp and it was 235! So it had to have been even higher since that's what it cooled down to after some cruising.
Put the shifter in D and normal mode, drove normally back home and noticed it was slipping between some gears (still pretty hot but cooled down to around 215-220). Pulled in my garage and I noticed the smell of burning oil. Lo and behold there was some transmission fluid dripping underneath, and it was spread over the exhaust like something had blown and shot fluid. I checked everything and couldn't figure out where it was leaking from, and no lines were obviously blown off.
Parked it overnight, and came out the next morning and there was no fluid on the ground. So I loaded my flex tune and have been driving around in normal mode and shifter in D, taking it easy, just going to work and back as I transition back to gasoline (have about 12 gallons of 91 now) and it has been shifting normal, with trans temps getting no higher than 194-199 when full warmed up which is where it always was before. I don't see any signs of fluid leakage.
I'm going to load the stock tune back in when I get a full tank of gas and probably take it to the dealership to have them look at it under warranty. But, do I definitely have some kind of damage? Or can something like this happen on rare occasions where the fluid heats up and sprays out of some overflow tube or something if the trans temp gets really high?
I don't want to push it to try to replicate that leak again, at risk of causing a bigger problem. At least not until I'm on the stock tune and if something happens I can just have it towed to the dealer for warranty work.
